Oil Leak
Driver side oil pan bolt (long bolt) was wet but like I said, it appeared to be coming from above.
My thoughts of possible causes are;
1) Oil Pressure Sending unit
2) Cam Sensor
3) Valve Cover Gasket
4) Valley Cover Gasket
5) Head Gasket (I thought only water would come from a leaking head gasket)
6) Rear Cover to Oil Pan
7) Rear Main Seal (again)
8) Oil Pan Gasket
9) ?????????????
Or something worse? What are your thoughts? Can you give me some direction, I would liek to get this thing tuned on on the road ASAP!!
Cheers!
Chad
I did use RTV in the corners of the Oil Pan at install. I thought I got enough in all 4 corners, maybe I was a bit short in the rear corners.
Chad
