BTR stage 4 cam in a 5.3?
Old Sep 1, 2017 | 01:24 AM
LETHL 03's Avatar
Default BTR stage 4 cam in a 5.3?
Has anyone had any experience with a BTR stage 4 cam (233/248 .618/.596) lift with 113 LSA? I just put a a 5.3 on my car with stock heads, just double valve springs and was thinking of a stage 4 cam. Car is a 1/4 mile weekend car with no street use and has 3800 stall.
Thanks
Old Sep 1, 2017 | 07:12 AM
svslow's Avatar
Might work okay with a 250 shot.
Old Sep 1, 2017 | 07:20 AM
JoeNova's Avatar
Restricted User
Too much cam for a stock 5.3.
Old Sep 1, 2017 | 09:11 AM
SLOW SEDAN's Avatar
Possibly a little big, but curious how it would work. We've used his stage 3 turbo cam 230/235 114 as well as a 231/239 113 and both work well in 5.3's we rev them to about 7500.
Old Sep 1, 2017 | 10:06 AM
jimmyp3353's Avatar
I put an MS3 cam in my LM7 when my custom grind failed. I know its not nearly the same cam but its a really big cam for the application like the BTR cam. The thing made NO power before mid 5k. and I have a 4000 stall, TH350, and 4.11 gear. If you were in a car that weighed 1000lb less it might be optimal. But, if you're in an Fbody you would need a 4400+ stall, and a huge gear to compensate for the power loss down low, and even then you would have to take it up to 7500. Here's a vid of a pull with it up to 7k.
Old Sep 2, 2017 | 12:10 PM
ddnspider's Avatar
I agree, a bigger stall would be needed and rev it to 7k+
