New 5.3L Build Questions
My goals is a naturally aspirated street motor for a 3rd Gen F-Body with a T56 and 3.73 gears.
I'm building the short block to stock specs but plan on modifications in 3 areas. Intake, heads, and cam.
To keep the costs down I'm looking at used GM LS parts for intake and heads. The cam I would get new. Looking to stay under $2000 for these items.
Intake (used) - LS6
Heads (used) - 243/799
Cam (new) - So many options available I need some help. Using stock lifters and 1.7 rockers (will install trunion upgrade). Would consider new dual springs if need be.
If there are better used GM or aftermarket options for intakes and heads comments are appreciated.
id personally go with bigger cubes if I was staying N/A. Maybe punch it out or find the motor and trans out of a wrecked camaro or firebird and get the harness too. Starting from scratch is hard. coils, injectors, etc add up quick and will nickel and dime you. It would be best to find a pull out motor with harness etc to make it easy. It will save you $$ in the long run.
I've considered a used core but the majority of parts like the rotating assembly, intake, heads, oil pan, gaskets, sensors, flexplate etc will not be used. So I don't know if $700-800 expense will be worth it for the parts I would actually use.
Which company is Pat G with?
NA power relies on lightweight, and large displacement. Take everything out of the car. Use lightweight body panels. Low resistance tires, and the lightest wheels you can find. Prioritize the wheels being lightweight forging. The pro of this kind of build is maximum fuel economy. It should be 6-speed and weight 3200lbs or less (preferably 2800lbs).
Don't mean to take everything literally when I post it "everything" to me is like "anything you can live without"
And yes I would lightweight wheels (if they are significantly lighter) > cam/head/intake
due mainly for the wide variety of effects they will have (more economy, more power, better handling and braking, it basically improves everything about the car)
because the wheels you can keep with the car, they also fit the next same car, and you can always re-sell them. If they are significantly lighter? yes it will make a huge difference.
And finally, this I only suggested because I wanted to make the owner AWARE Of these things. No, don't prioritize wheels right now, that is just ridiculous. Even I've never purchased a new set of wheels. What a waste of $$$. But as long as we are AWARE of the positive influence a nice lightweight set of XXXX will have, we can make informed decisions about other things too (because now "I" see how important weight and rotating weight is...) I can think critically about the future of the car in terms of performance and economy.
budget = max fuel economy.... so yeah still king correctness ;X I am starting to love you though.
since your on a tight budget, go with the 5.3, find a pullout. You can't use the harness with it though, it was designed for autos. Find a cheap t56 off eBay or this forum in the classifieds
2000 bucks for 243 heads and ls6 intake should be doable. As far as drive train:
motor- at least 500 bucks for a good running motor
trans-1500 to 2000
miscellaneous- a **** ton.
I'm telling you, it's so much easier and cheaper to find a pull out. Even if you go with summit block, it will require machine work.
I appreciate the wisdom of the collective.
My intent for starting with a bare block was not just to save money but to take my time and enjoy scrounging for parts. I'm in no hurry and part of the enjoyment for me is getting each new piece.
But I do see a couple of points here. For a NA motor, displacement is your friend and I'm going to check prices for a used LQ4 today at a couple of local yards.
Also is "Pat G" Patrick Guerra? I think I found his web site.
I'm doing my own personal car, 1978 trans am ws6 and I thought i could do it for 20k
That turned into a complete restoration and 80,000 dollars later, the car is still no where close to being done.
It has the harness and I've read some threads here about converting it over for a T56.
Thanks for the input all.
