Need LQ4 Build Suggestions
Old Sep 5, 2017 | 10:25 PM
MustangBeater20's Avatar
Default Need LQ4 Build Suggestions
Just bought a '69 Chevelle and was planning to TKO600/LS Swap it. Would like some suggestions on building a LQ4. Budget is around 3k-4K. My ultimate goal is 500ish hp at the CRANK. Would a LQ4 with 243s and a 228r cam with a LS6 intake get me close to my goal?
Old Sep 5, 2017 | 10:32 PM
For that kind of power, either get a GOOD port job on those 243's or use either TFS or AFR castings. The LS6 intake might get there, but a FAST would do you better for 500HP. I would also use a cam with more exhaust split, but that's just me...
Old Sep 5, 2017 | 10:36 PM
What could I expect with that setup I suggested?
Old Sep 5, 2017 | 10:47 PM
I will not venture a guess, but with AFR 245's(or TFS equivalent) and a FAST manifold, plus a stout cam, that 6.0 SHOULD come close to reaching your goal.
Old Sep 5, 2017 | 11:36 PM
88stanger's Avatar
i just spent over your budget top for a 5.3 build with nothing super special to be honest. now i replaced every sensor, alt. starter, AC pump, you name it i did it, but my all in costs are over your budget to be honest. Not saying you cant do it, but i did a complete rebuild, bored block on up. Just to give you an idea where i am at. As for the 500hp, that i am not at, but maybe 400 to 425 or so. I did spend so good money on intake and heads.
Old Sep 6, 2017 | 08:30 AM
TrickFlowTech's Avatar
LS1Tech Sponsor
The As Cast 220's would put you a hundred over your goal with the FAST as others have stated. The Dorman would get you pretty close for less $. Could go with a bit more cam, but whacking the heads to 60cc is a good move throughout the powerband.
__________________
Old Sep 6, 2017 | 08:34 AM
HCI2000SS's Avatar
500 hp at the crank is probably around 420-430 at the wheel, so the HCI you have listed it should put right in that area no problem
Old Sep 6, 2017 | 09:44 AM
Would a 228r be plenty streetable with stick shift?
Old Sep 6, 2017 | 10:07 AM
HCI2000SS's Avatar
With a good tune it will be very streetable
