pumping oil thru a non running engine?
Old Sep 17, 2017 | 03:51 PM
fouz65's Avatar
Default pumping oil thru a non running engine?
short story is motor has been sitting since 2009. looked at what i can with an endoscope and everything looks good. but...
how would someone pump oil thru a non running engine (like an accusump) so you can turn the motor over with a drill to pre lube everything before restarting.
i lubed the cylinders and turned over with a drill for 10-20 secs but dont wanna toast a bearing.
i have a few ideals how to pressurizer the oil but where would the input be?
Old Sep 17, 2017 | 05:41 PM
Joie_C's Avatar
You put a threaded fitting in one of those oil galley plugs and pressurize a tank of oil with air behind it. It'll pre lube everything. I think I saw agearhead4life on youtube do a vid on this. Its very simple.
Old Sep 17, 2017 | 05:48 PM
madsv1000's Avatar
Agreed yeah his video has the best and budget friendly setup.
Old Sep 17, 2017 | 06:05 PM
fouz65's Avatar
found it! thanks guys. about what i had in mind just didnt know where the input should be.
Old Sep 17, 2017 | 07:11 PM
qweedqwag's Avatar
cool idea. good job.
Old Sep 18, 2017 | 03:38 PM
joyridin''s Avatar
Get the fitting that screws into the front of the engine. Then go to Home Depot and buy a $9 sprayer that you would use to spray trees etc. Cut the little spray end off, connect it to your fitting, and pump it up. I would send you mine but the shipping is more than it would cost you to make it. The gauge read 20 psi using that sprayer.
http://www.homedepot.com/p/HDX-1-Gal...1HDX/207202420
Old Sep 18, 2017 | 07:56 PM
fouz65's Avatar
i bought some stuff today but i think ill take it back. i like the sprayer better. dont have to make anything and can see the oil level. win win. big thanks joyridin.
where can you get the fitting for the block thou?
