Broken spring!!
LS1 241 heads (I'm assuming stock springs)
full exhaust ls6 intake
228/228 comp cam
Started the car heard a clacking noise..
removed the valves an the 2nd driver side rocker an the spring was broke.. the valve was still up. The pushrod was fine. I'm looking at PAC springs with a .600 lift.. What is confusing is it had valve seals. Now if I upgrade to a better spring do the seals come out an the seats go in?
