line on cam lobe - problem?
Old Oct 14, 2017 | 02:53 PM
patSS/00's Avatar
Default line on cam lobe - problem?
This cam just came out, it's got 30K miles, one lobe has this wear line, should I be concerned? No obvious wear on any other lobes. It's stock, lifters stock. Really don't want to have to replace lifters at this point.
Old Oct 14, 2017 | 03:25 PM
Can you feel this line, as you drag your fingernail across it?
What does the lifter look like from this particular lobe?
Old Oct 14, 2017 | 03:38 PM
patSS/00's Avatar
Can't feel the line with my fingernail. Since the engine's in the car and the heads are on, and that's #7 farthest back, can't see the lifter at all.
Old Oct 15, 2017 | 09:34 AM
NHRAFORMULA00's Avatar
if you can not feel any groove in it, it will be fine. make sure you lube it up with assembly lube, not oil, when putting it back together.
Old Oct 16, 2017 | 05:58 AM
vettenuts's Avatar
I would try to get a look at that lifter if you can. You can buy a borescope for your phone on Amazon for around $25. Hook the end to a long rod and aim to it examine the lifter wheel.
I would personally be very hesitant putting the motor back together with that cam and not knowing the source of what happened.
Old Oct 16, 2017 | 08:02 AM
01ssreda4's Avatar
If you cant feel it then it is probably fine. Seeing where the lifter rides is normal. Engine oil is also normal for short term assemblies, assembly lube is only needed if the assembled engine is going to sit for a while.
Old Oct 16, 2017 | 11:52 AM
patSS/00's Avatar
I like the borescope idea, but I don't know if I could get a definite answer with that, what if there's some small damage spot on the lifter roller but it's facing the wrong way so I still can't see it? The rollers do turn right? Actually I don't see how there'd be a line all the way around the lobe like that if the roller is turning, is it possible for the rollers to stick so they don't roll?
I'm using Lucas oil stabilizer as "assembly lube" thanks to another poster on here, it's cheaper but works great for coating things and pure oil based.
Old Oct 16, 2017 | 12:01 PM
If the roller stuck it would grind itself down and cause even bigger problems than you are now getting.
 Michael S. Palmer
Old Oct 16, 2017 | 12:14 PM
JakeFusion's Avatar
Super Hulk Smash
Looks like debris got caught in there.
