Knocking/ticking after overheating
Old Oct 27, 2017 | 11:04 PM
Chevyy1212's Avatar
Default Knocking/ticking after overheating
2000 LS1 ended overheating shut it down fast but was running slightly hot a little bit before. After a good 30 minute cool down I fired it back up and there's a knocking/ticking noise. I took it to a shop they diagnosed the cooling issue but all the said about the noise was sounded like a loose heat shield. Then a Friend GM tech said he turned the engine over by hand and it stopped at a point which said bent connecting rod.
It sounds like something is slapping the exhaust up by the header.
​​​​​How many different things can cause a knocking/ticking after over heating I keep hearing head gasket but what else there was no ticking before. Thanks
Old Oct 27, 2017 | 11:12 PM
RockinWs6's Avatar
Carbon can break off a piston and cause such noises.
Old Oct 28, 2017 | 05:30 AM
Chevyy1212's Avatar
This would require a tear down to fix tho I imagine? To me it almost sounds like the noise is being amplified by the exhaust so I went with the first shop that said heat shield then another said bent connecting rod... Not sure if excess heat could cause exhaust manifold gasket to go?
Old Oct 30, 2017 | 04:20 PM
nine8ss's Avatar
You could easily have a bent rod and created an exhaust leak. Heat can do some really bad stuff to your engine. Without opening it up and examining the damage from the overheat, its very difficult to know the extent of your misfortune.
