Oil Pressure fell to 0! Help
Old Jul 1, 2004 | 04:41 PM
Damage Inc.'s Avatar
Sweet Cheeks
Default Oil Pressure fell to 0! Help
I started my inernally stock 99 Camaro today and the check gauges light came on. I knew I had gas and OH SH&Y! No oil pressure! I started it again and gave it a little gas and the valvetrain started ticking. I immediately shut the car off. Could I just replace oil pump? What else could it be?
Old Jul 1, 2004 | 05:08 PM
MyLS1Hauls's Avatar
Bet the relief valve stuck in the pump. For some reason, some of the older pumps have relief valve problems. Just replace the pump with a new stocker and you'll be good to go.
Old Jul 1, 2004 | 06:48 PM
Sweet Cheeks
Awesome, I hope that's all it is. I've decided to order a G5X3 and slip it in while I'm at it.
Old Jul 1, 2004 | 07:01 PM
Fireball's Avatar
yup...probably just the pump stuck open
Old Jul 3, 2004 | 11:13 AM
Sweet Cheeks
Thanks. Will an LS6 pump be fine or is there something better?
Old Jul 3, 2004 | 12:26 PM
kossuth's Avatar
Stock LS6 pump will work just fine. You can go for a ported pump but a stocker will do fine.
Old Jul 3, 2004 | 01:08 PM
jd13's Avatar
You're gonna have to "slip in" new valve springs while you're in there as well.
Just making sure you know.
Old Jul 4, 2004 | 12:51 AM
Sweet Cheeks
Comp 921s sound good? Lou thinks they'll work just fine. Ha! Thanks for your help guys.
