Cam Comparison LSL lobes vs...
Old Nov 21, 2017 | 01:13 PM
  #41
00pooterSS's Avatar
Originally Posted by G Atsma
And that's why Comp's name is headed straight for the gutter around here...
Guess I haven't been keeping up, what are the other complaints, especially and common ones?
Old Nov 21, 2017 | 01:24 PM
  #42
A.R. Shale Targa's Avatar
Originally Posted by JakeFusion
Just make sure it's Post-Jan 2016 build date for their new "tech" to make it into the cam.
bought my custom cam from Texas Speed in December of 2014(ground by Comp)no issues as of yet however only about 3500 miles on since fresh build
Old Nov 21, 2017 | 02:11 PM
  #43
JakeFusion's Avatar
Super Hulk Smash
I know it's only one data point, but one I had was nine degrees off. Advanced. At first, I thought it was a tooth off, but moving it a tooth moved it 18 degrees, so it was half a tooth off. So, mine was a grinding error.
Comp uses older machines for one-off custom ground cams. That's why I DO NOT RECOMMEND you get a custom cut Comp Cam. It will be a crapshoot.
Get a shelf grind cam. They use their new CNC machines to cut bulk cam orders. They are typically within .5 degrees. So like BTR or Speed Inc or any of the folks who stock "shelf" grinds of their own design, are cut in bulk orders. And those are well tested. So they work.
If you truly need a custom cam, Cam Motion is the way to go.
Old Nov 21, 2017 | 02:27 PM
  #44
Cam material and spring failure, especially among the popular 918's
Old Nov 21, 2017 | 02:29 PM
  #45
00pooterSS's Avatar
I remembered the springs. Just wondering if I missed anything, thanks.
Old Nov 21, 2017 | 02:30 PM
  #46
There was a problem with lobes scuffing really bad. Suspected bad hardening process.
Old Nov 21, 2017 | 05:20 PM
  #47
Darth_V8r's Avatar
Moderator
I didnt realize this. Very good to know
Old Nov 21, 2017 | 05:22 PM
  #48
Darth_V8r's Avatar
Moderator
And keep in mind - i am just one data point. Others had fantastic results with a comp cam and 918 springs.
I want to say over 50% of the cams out there are ground still by comp.
Old Nov 21, 2017 | 07:19 PM
  #49
Stats are funny that way. As many cams, etc. as Comp has out there, 1% is a number that still gets your attention. And a few bad apples.... well you know the rest!
Old Nov 21, 2017 | 07:29 PM
  #50
JakeFusion's Avatar
Super Hulk Smash
Also, Comp is now offering a mirror polish/finish on all new cams called (microscopic surface enhancement) MSE. Just saw that today.
Old Nov 21, 2017 | 08:11 PM
  #51
Keeping up with the Joneses....
