About to fire motor for first time
Old Dec 17, 2017 | 05:22 AM
HappySalesman's Avatar
Default About to fire motor for first time
Just wondering if there's any last minute things I should do or look for. I primed the oil system (granted it's been a few weeks, but I know there's oil in the motor), coolant is topped off. Any thoughts or just fire it and go?
Old Dec 17, 2017 | 05:47 AM
98CayenneT/A's Avatar
I usually meditate like Nicholas Cage before he starts Eleanor
Old Dec 17, 2017 | 06:12 AM
enyo's Avatar
Make sure all your sensors are plugged in. Knock sensors and grounds are easy to forget in the back.
Old Dec 17, 2017 | 07:16 AM
Hardtop Brian's Avatar
Map sensor behind intake is plugged in, radiator fans are plugged in (i missed this one and it boiled a gallon out while I was filling it lol), eye on oil pressure gauge for first second or two. Pressurize fuel system and check for leaks if you messed with it.
Old Dec 17, 2017 | 11:38 AM
YOU TOO???? lol
Old Dec 17, 2017 | 11:51 AM
z-maro's Avatar
Grab the video camera for that "first startup." Don't freak out with the bit of smoke that will come out of the engine bay after touching everything.
Old Dec 18, 2017 | 02:44 PM
00pooterSS's Avatar
I personally like to do a heat cycle or two before driving it. But I have had engines where I didn't have time to and they were fine. Make sure your tune is pretty good before running it too long, if it's too fat you can wash the oil off the rings.
Old Dec 18, 2017 | 03:50 PM
LLave's Avatar
I like to pull the fuel pump fuse and turn it over a few times to get the oil moving. Not sure it makes any difference but it makes me feel better.
Old Dec 18, 2017 | 07:54 PM
I do this too
Old Dec 19, 2017 | 06:28 AM
Whelp, fired it up and it runs great! Had oil pressure almost instantaneously, runs like a champ!
Thanks guys. I'll be posting a video of it in my build thread.
Old Dec 19, 2017 | 08:11 AM
Darth_V8r's Avatar
Moderator
I do this. I also fill the oil filter with oil before installing it, so oil is circulating almost immediately - no delay due to filling the filter.
Old Dec 19, 2017 | 10:03 PM
Pre-filling your oil filters is the single most important step in this process. I fill mine at every oil change as well.
Old Dec 19, 2017 | 11:18 PM
In my tenure working at a service/filling station (now an extinct breed...) filling the filter before startup after an oil change was SOP. You didn't think twice about it. The exception being those filters that installed open-side down, obviously.
Old Dec 20, 2017 | 02:11 AM
Or the ones that are sideways. I will never forgive saturn for putting their oil filter in the most annoying location i've ever seen.
Old Dec 20, 2017 | 02:55 AM
98itrLSFX's Avatar
Everytime 😁
Old Dec 20, 2017 | 07:04 AM
Darth_V8r's Avatar
Moderator
I also do this when eating a steak in front of a vegan. And I loudly thank Baby Jesus for the cow that gave its life to fill the plate where I don't have any mashed potatoes.
