Turbo motor ran NA
Old Dec 29, 2017 | 09:38 AM
fastlt1's Avatar
Default Turbo motor ran NA
Anyone run Turbo motor NA. I'm thinking a 408 with 9.5 compression and a turbo cam. How would it run NA. Better then stock ls1. How much better
Old Dec 29, 2017 | 11:12 AM
HCI2000SS's Avatar
I think that's going to depend, but i know an old friend of mine had a stock LQ4 in his Z28 and with a full exhaust and turbo cam it ran pretty damn good n/a
Old Dec 29, 2017 | 07:00 PM
ddnspider's Avatar
My 9:1 383 was somewhere between 375 and 400w....so yes better than a stock ls1. That was when the turbo was off the car for awhile.
Old Dec 29, 2017 | 07:40 PM
fastlt1's Avatar
Would there be any problem running deka 80 and a 3 bar SD tune just N/A
Old Dec 29, 2017 | 07:43 PM
ddnspider's Avatar
Not if it's tuned for it. I did alot of reading before I had my motor built and you typically want to break in the engine how it's going to live....i.e. if it's going to be boosted then break it in that way, but if that's not an option, then yes it will run ok NA.
Old Dec 30, 2017 | 09:24 AM
01ssreda4's Avatar
As long as the tune is correct it will run well. 9.5 compression is not that low.
