Ls1 pushrods question
But you are right somehow I screwed up my calculation using the length checker. I don't know how I did that because I re-did my calculation like 10 times. Now I don't know how I screwed that up so bad.
So now that screws me even more lol.
Comp Cams method = 7.325"
Other method = 7.367"
in my experience, using the length checker, it's too easy for it to turn. I set it to a length, verified that length with the digi calipers, and put something on the checker to hold it at that length. Checked to see if i got zero lash. did it over and over again until i was satisfied with the measurement.
i would try to stick some teflon on the threads on the length checker, or even use some tape to hold it from turning. set it to a length and make sure it won't budge, then insert and tighten down the rocker. Got lash? a little longer. it's tight and can't wiggle it? a little shorter. use the digital caliper to measure. when you get right to zero lash, that's it, add your preload, find out what the actual pushrod length is from comp or whoever you get your pushrods from, and order the closest size. then when you get your new pushrods, MEASURE THEM TOO.
And unless you're getting a custom size or have a set of aftermarket lifters with a short travel, just aim to be as close to the right preload as you can get. with OEM LS7 lifters, you have a little leeway. some aftermarket lifters are a little less forgiving.
I might just go with .075 preload instead of the .050 I was using and go with an adjusted length of 7.350".
And, measure the actual length with a set of digi calipers.
And it doesn't sound too short if you have a set of heads that have been milled significantly.
OK your op said ls7 lifters, that much preload should be ok. I wish i could find the lifter travel data i had saved.
IIRC, the LS7 lifter cup sits a little higher than previous LS lifter designs.
To my surprise I recorded values between 1.25 and 2.25 turns. The 1.25 turns I think is good but a few at 2.25 turns is puzzling. I did a quick test fire without the balancer and water pump. Fired right up, 60 psi, sounds great, but looking for explanation on apparent pre-load variability.
In this case it would appear that using the pushrod length checker would yield a whole range of pushrod lengths ??
UPDATE: Just put a cam gear on the old cam and positioned it as described above. Clearly the lobe was NOT always on base circle, sometimes onto the ramp just a bit. A cam/sprocket on the bench is a really good visual tool to see where the lobes are at various gear "dot" positions. Comparing my detailed turn notes per rocker it was evident that the ones on the base circle were all 1.25 turns.
So the bottom line is that with the lobe for sure on the base circle 1.25 turns which is perfect.
Other values that were up to 2 turns reflect that there was just a bit of lift that had to be compressed from being just off the base circle.
Learn something everyday!!
this thread has the correct gm rocker torquing procedure.....aka how to know when the lifters are on the base circles.....aka how to be sure to know what cylinders to measure and when
Don’t go by TDC/dot to dot to calculate lengths. Please make sure that the intake is on the base of the cam/exhaust closed/past TDC, and vice-versa when measuring exhaust).
