ls1 piston info and compression?
Old Feb 15, 2018 | 01:54 PM
99ssvertm6's Avatar
Exclamation ls1 piston info and compression?
okay so i ripped the heads off my camaro last night after its been smoking for a good couple months to discover a hole in piston 7 and 2 cylinders that appear to have bad oil rings so a rebuild is in order my car is currently bone stock with the 241 heads witch if i have my research right that puts it on stock pistons at about 10.1 compression so my question is what do i need to know about pistons to pick the right one for my application i dont wanna go wild with it but id like to fully rebuild and set up for 93 only and about 400hp its not gonna be a track car just a fun daily so if some one can give me the basics of what i need to look for it would be nice i can rebuild a motor with a kit but have never strayed from stock internals so i dont wanna just throw parts at it and hope it runs okay with right power band so what do i need to know about the pistons heads and head gasket to figure out my compression ratio and whats right for me if any more info is needed please ask
Old Feb 15, 2018 | 02:56 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
We have direct drop in pistons and rings for your combo that will handle your power goals just fine!
Even if you need a hone, we have em in 3.898 and 3.908.
Find em here
Old Feb 15, 2018 | 02:57 PM
We also have the best price on install kits, ls7 lifters, and so many cams to choose from!!
Email for more info
Rpmspeedtech@gmail.com
Old Feb 17, 2018 | 07:36 AM
LS1 pwrd NOVA's Avatar
What about 6.0 pistons, you have those in Flat-Top as well?
Old Feb 18, 2018 | 03:21 PM
We have flat top 6.0 pistons also. They come with a hard anodized top and 1st ring land as well making them pretty tough.
Old Feb 18, 2018 | 07:51 PM
Can you post a link as I only see high dollar ones?
Or is that all you have for a stock rebuild or to turn an lq4 into an lq9?
Old Feb 18, 2018 | 07:54 PM
They arent on the site yet. we have em on hand though. in stock bore, .020/.030/.040 oversize.
They are $350 for the set with std fit rings.
