2002 lm7 5.3 head studs
Old Mar 4, 2018 | 06:22 PM
Auzzybear's Avatar
Default 2002 lm7 5.3 head studs
Hello I知 building a 2002 lm7 5.3 and I知 putting 2010 243 heads on it what studs do I need for the heads? The same length ones or different length ones? I know they switched in 2004 I知 just not sure which ones I壇 need
Old Mar 4, 2018 | 08:12 PM
kossuth's Avatar
The 243 and 862/706 heads all use the same length of bolt on the same block. IE you get the studs based on your block type. Head type in this situation has no bearing.
Old Mar 4, 2018 | 08:18 PM
98CayenneT/A's Avatar
Originally Posted by Auzzybear
Hello I’m building a 2002 lm7 5.3 and I’m putting 2010 243 heads on it what studs do I need for the heads? The same length ones or different length ones? I know they switched in 2004 I’m just not sure which ones I’d need
In 2004 they switched to all the same length.
In total a set of studs for you will have 3 different sizes for your application.
Long, 4 medium, short
(2 mediums per cylinder head)
Old Mar 4, 2018 | 10:04 PM
Auzzybear's Avatar
Thanks guys I couldn稚 find any info on this so I値l need the long and short bolts for mine since it痴 a 2002 block I believe the arp part number is 134-3609
