Ls6 cam in 5.3l HELP!
I have a ls6 cam springs and stock push rods all from the same motor.. I'e read I needed ls7 lifters? I' totally clueless on this part so all I need to know is what do I need to make this work. Not looking for major hp gains just need to know what I need to make my ls6 cam work in my 5.3l thank you
Should be a simple swap. The ls6 Cam has a smaller base circle so you need the ls6 pushrods. If you have those you should be good to go. However as always make sure you check your lifter preload
