I'm trying to figure out if this is a genuine texas speed ms3 cam I cant seem to get an answer tsp cant help so I was wondering since a lot of people had this cam if you can tell me if it is that cam or not. I know someone carved it into it but that doesnt mean that it is that cam I cant seem to figure out if the numbers in it from factory are it or not when I Google it it comes up links to comp cams and tsp so Idk any help would be appreciated...
If I'm not mistaken, Texas Speed cams used to be ground by Comp until Comp had a series of issues. So it's very possible that it's an MS3 from before TSP started grinding their own.
I talked to tsp and they said it was a comp grind but to call comp and give them the number on the bottom of the cam and that means it the serial number and the -10 means it was made in 2010. But the numbers before that are the serial number and I can call and ask if they may know just so I know for sure it's the ms3 cam and not something else I didn't want to install it and find out it wasnt what it was suppose to be.
