Hydrualic Roller VS. LLR VS. Traditional Solid Roller
Old May 7, 2018 | 02:15 PM
  #81
Tuskyz28's Avatar
I personally like the idea of running shaft mounted roller rocker arms with link bar lifters and a hydrauic roller.
One of the highest rwhp 40X motors I've seen in here does just that.
Old Jun 15, 2020 | 03:10 PM
  #82
bortous's Avatar
Great thread.
Very educational.
Old Jun 16, 2020 | 12:25 AM
  #83
rednari2's Avatar
Originally Posted by A.R. Shale Targa
Your wording still seems backwards. An all aluminum engine will “GROW” the lash about ten
If Crane wants 22 hot then room temp is twelve. Different cam companies shape their lobes to safely run with specific clearances
Steve is only referencing tight lash. Which are quiet stable and easy on valve train parts.
And there is no blanket yes or no to your magic “more” question
Manipulating the lash specs can simply change the rpms where it makes its torque. Too far either direction can wreak havoc on parts and usually points towards the wrong grinds specs for the build
This rises from the dead. I did not understand what some forum members were driving at, at the time. My question concerned why the lash was set at zero cold for low lash solids. Answer. It grows to .010 when hot due to aluminum expansion. OK. So, it operates at .010 instead .022 when hot. What was lost at the time, is that .022 hot lash was Crane's hot lash spec for their cams. An aluminum motor would shrink (contract) about 10 thousandths from that setting when cold. So ,the cold lash would be closer to.032 after shinkage, which I thought was alot.
Assuming, the parts shrunk together, that is the steel push rods and lifters as well as the block and heads, the lash would increase anyway since the steel contracts less than the aluminum, So, on cold start up the sticks would really clatter, while the LLSL set up shrinks to zero. Interesting. When I mentioned this to Cranes back then, I was instructed that that amount of lash was needed and that the lash section of the heel would take it up. This immediately made me realize the cams are obviously ground differently. Second, Cranes at that point had never heard of a low lash cam set up.
Anyway, Cam Motion found a way to offer a solid camshaft without the cost of adjustable rockers. Interesting.
Old Jul 7, 2020 | 01:40 PM
  #84
bortous's Avatar
Lol.
You still don't get it.
Old Jul 7, 2020 | 01:48 PM
  #85
Darth_V8r's Avatar
Moderator
Cold lash would be 0.012, not 0.032. With an aluminum block, you lose lash as it cools, due to the aluminum shrinking faster than the pushrods. The pushrods become relatively longer as the motor cools.
Old Sep 20, 2020 | 04:07 AM
  #86
Firebirdmuscle's Avatar
Great thread. Thanks speed, darth, and cam motion for the informative replies in here.
Old Sep 22, 2020 | 10:47 AM
  #87
rednari2's Avatar
So, you are saying the block shrinks .010 but the pushrods don't shrink at all. They contract at a lesser rate than aluminum, but no shrinkage at all? Also you are setting the lash at zero when cold. When hot that would open to about .010. Cranes suggests .022 when hot and that the lash section of the cam will take it up. These Cam Motion cams must have different lash grinds for it to work. When I talked to Cranes, they explained the valve train needed the lash and that they did not know what Cam Motion was doing. They did not say it was wrong, but that their cams would not work with such tight lash adjustment.
Different systems I suppose.
Old Sep 22, 2020 | 11:33 AM
  #88
speedtigger's Avatar
Old School Heavy
All of the various metals will grow with heat and shrink with cold. Aluminum will grow more than steel and cast iron. On a typical, standard-deck, LS engine, this is about what you can expect in a typical temperature range: An aluminum block and head will grow about .010" more than the valve-train when the engine goes from cold to hot (typical operating temperatures). A typical iron block and aluminum head will grow about .004" more than the valve-train when the engine goes from cold to hot (typical operating temperatures). So, if you set the lash to "0" cold, an aluminum block and head LS combo will be about .010" hot. On an iron head and aluminum head combo will grow to about .004" when hot. If you want .010" hot lash from your iron block and aluminum head combo, you might start at about .006" cold and check once hot to verify.
Extreme cold conditions and/or extremely hot engines will have more variation. It does not matter who's camshaft that you use, these are the expansion rates you can expect on a typical production, standard-deck LS engine. Tall deck blocks or larger engines will experience more growth.
Lash adjustments recommended by the camshaft manufacturer are based on the lobe design. It is best to follow the manufacturers recommended lash setting for their design to start. Small adjustments can be made to lash in an effort to fine tune the performance of a given engine. However, loosening (increasing) the lash too much can create harsh conditions and cause damage to the valve train. Consult the manufacturer on the maximum lash range for a given lobe design for your particular application if you intend to deviate from the recommended lash to help avoid damage to your valve-train.
Let me know if you all have any questions on this and I will try to answer them. ~ Steven
