408 stroker cam help
Old Apr 13, 2018 | 10:00 PM
hollaback6's Avatar
Default 408 stroker cam help
hey guys i am currently have thompson motorsports build me a 408 stroker motor for my 04 gto. I will be running had ported 243 heads with ls6 intake manifold. i realize that the heads are going to choke the motor a bit up top but i really am out of money for now. the car has a plate kit on it and will probably see a 200 hit of nitrous on 91 pump. i am up at elevation of 5500ft in new mexico. The DA is usually 6500 to 9000ft here so i am fighting elevation bad. compression should be close to 11:1 thompson specd me a cam that is this:
236/250 .625/.625 115lsa
the car is going to be a weekend fun car with the track maybe 2 a year. and i want the car to have a decent lope at idle and have a good powerband but still pull decent up top. is that cam going to get me there? what can of idle should i expect? and what kind of power band? will this work well with the nitrous? thanks
Old Apr 13, 2018 | 10:24 PM
HCI2000SS's Avatar
That sounds like more of a nitrous grind over a n/a one. If it's mainly going to be driven n/a I'd choose a different cam. That's just my opinion
Old Apr 14, 2018 | 09:43 PM
garygnu's Avatar
nitrous cams tend to hurt NA torque ,some time they are ground to release some cylinder pressure .
Old Apr 14, 2018 | 10:19 PM
hollaback6's Avatar
I just want a cam that has a good lope at idle, and runs strong na but responds decent to nitrous. I had a torque v3 cam in my ls1 gto and it had good top end and did well on nitrous.
Old Apr 14, 2018 | 10:32 PM
HCI2000SS's Avatar
That cam should sound oretty good with that duration, but again if it's mainly a n/a street car I'd choose something more befitting of thst
Old Apr 14, 2018 | 10:53 PM
Darth_V8r's Avatar
Moderator
Anything with at least 8 degrees of split should respond very well to spray.
Old Apr 24, 2018 | 01:21 PM
Broken944's Avatar
A cam properly specced for the motor should respond very well to nitrous. No need for a "nitrous cam". It'll only hurt the n/a performance with minimal(if any) gains to performance on spray.
