valve lifter trays
Old Apr 26, 2018 | 03:03 AM
adrsand's Avatar
Default valve lifter trays
what is the tolerance or clearance of the valve lifter trays in my ls1? I want to install a cam with .650 lift to my ls1 can it tolerates with out modifications?
Old Apr 26, 2018 | 06:41 AM
vettenuts's Avatar
Are you concerned with the cam lobe hitting the tray? It will never do that since the lifter projects out of the tray well over an inch.
Old May 2, 2018 | 08:29 PM
wannafbody's Avatar
.650 is too much for stock rockers. I've read no more than .630 for stock rockers.
Old May 2, 2018 | 08:44 PM
I've heard .600 is pushing it for stock rockers, as the tip, or nose of the rocker digs into the valve tip
Old May 3, 2018 | 06:06 AM
vettenuts's Avatar
OP was asking about the lifter trays, not the rockers. However, haven't seen him come back into the thread either and this was his only post to LS1Tech and the last time he visited according to his statistics.
Old May 3, 2018 | 10:30 AM
wannafbody's Avatar
I have the BTR stage 2 with .617 lift on stock rockers and my muilder said it's fine and he's done a lot of LS cam swaps.
