Quick ? about Crank bolt removal
Old Jul 6, 2004 | 12:05 PM
ellessone's Avatar
Question Quick ? about Crank bolt removal
Can you just put the car in gear and try and remove the bolt or do you need to stick a screwdriver in the flywheel teeth? TIA
Old Jul 6, 2004 | 12:14 PM
McRat's Avatar
Manual trans - Put it 6th gear.
Old Jul 6, 2004 | 12:23 PM
2xLS1's Avatar
And set the parking brake real tight.
Old Jul 6, 2004 | 12:28 PM
ellessone's Avatar
right on, thx guys
Old Jul 6, 2004 | 12:40 PM
McRat's Avatar
And block the wheels.
Old Jul 6, 2004 | 12:57 PM
383_98_LS1's Avatar
Or you could but the socket on with long braker bar, brake it loose with the starter.
Old Jul 6, 2004 | 01:47 PM
1fastWS6's Avatar
Sounds like a great way to destroy a starter or flywheel.
Old Jul 6, 2004 | 01:49 PM
TNormZ28's Avatar
1/2 inch impact gun
 Michael S. Palmer
Old Jul 6, 2004 | 02:31 PM
McRat's Avatar
Not very safe:
Normally you disconnect the battery before working on engine.
Should the wrench slip, it could get ugly.
Old Jul 7, 2004 | 12:23 AM
soundengineer's Avatar
put th evehicle in 6th gear.... put the e-brake on real tight.....have buddy put all his force into the brake pedal.......
and stil turn the wheels when you try to break it loose.....
guess I just have gorilla strength when it comes to wrenching on stuff...
Old Jul 7, 2004 | 07:51 AM
haole_boySS's Avatar
Originally Posted by SS1421
1/2 inch impact gun
Werd! bolt off in 4.6 secs.
Old Jul 7, 2004 | 09:42 AM
SuperC1's Avatar
Put the car in sixth gear and use a breaker bar and strap wrench to help hold the pulley while you turn the bolt. Give it some good pressure on the breaker bar and it'll come off.
Old Jul 7, 2004 | 10:57 AM
erok01's Avatar
first you might want to take your skirt and blouse off, then put a little bit of *** into it.
if that doesn't work i can loan you my impact gun, but its going to cost you some
Old Jul 8, 2004 | 10:00 AM
eallanboggs's Avatar
Use a chain wrench.
Old Jul 8, 2004 | 10:57 AM
robertbartsch's Avatar
I put hte car into gear and use a breaker bar plus a long 3 foot lead pipe....these crank bolts are REALLY tight - 240lbs - I think!
I doubt a 1/4 impact wrench would work but I never tried one....
Old Jul 8, 2004 | 03:47 PM
dropkick's Avatar
I just dropped the starter, only 2 bolts. There's a hole in the flywheel (i think it's 1/4" dia.). You can insert a pin (i used a phillips screwdriver) in the hole to lock the flywheel.
