4.185 x 4.100?
The 243 head was designed for a 5.7. It will do decent on your 451, but I think it will hold it back. If you are dead set on staying cathedral, then you should be looking at AFR or TFS or one of the other sellers who starts with their castings and makes great heads out of them. But beyond the heads, consider the intakes - unless you jump to something pricey, I think are going to further choke you back. THe LS6 intake is great on a 346. That 78mm throat is going to choke that 451 hard. There have been lots of dyno runs showing that larger engines like intakes with shorter runners - even for improved low end torque. The only short runner option cathedral is the MSD, which will run you >$1K without any port work.
The combustion chamber of the LS3 head is superior to the 243, The LS3 heads are cheap, the intake options are so much better and more plentifule. ****, a stock LS3 intake is the best factory intake you can get. Have it rod-modded a la Rick Crawford, and it picks up even more (radius rods at port entry) and performs almost on par with out of the box fast 102. Then, just run less cam to compensate for the larger heads. There is a valid argument on smaller engines to stay cathedral for improved low and midrange torque. On a 451, you don't have to worry about it unless you way overshoot the cam. Put a 5-cc valve relief / dish on the pistons, with 70cc chambers, you're at 12.1:1. Stock LS3 heads and intake will cost you so much less than any other option for the performance you'll get from them.
This will be a REALLY odd cam recommendation to match it, and it might start a interesting....disCUSSion, but 230/242-117+2. Not a typo. That'll put you at 8.7 DCR to go with the 12.1 SCR, IVC of 50, EVO of 60, overlap only 2 degrees. You'll have tremendous intake vacuum, it'll have great throttle response, and it will definitely get that truck moving. That cam in a 346 would be a high RPM cam. In your 451, it'll be a stump puller with those LS3 heads. Will run great on 93 octane.
Whatever you decide, best of luck with the build.
The LS6 is an excellent intakes and works well with 346 5.7's and 383's with the 90mm snout and a fan of the LS6 intake
However, the LS6 or LS6 90 will limit any healthy 451 with a good set of heads and cam in my opinion.
The 451 would be a good candidate for a ported Fast LSXRT with the 102 NW TB if your staying with cathedral heads. I would want a set of ported Trick Flow or ported AFR's or similar.
The 451 is also a great candidate for rectangular port LS3 heads ideally with a little porting to clean up and a ported Fast LSXRT or LSXR.
In a truck, I’m not really sure what pan you can use. The tricky part is getting the windage tray to clear the rods, but it’s usually not much more than spacing it out with a washer or two.
It will probably need minor clearancing at the bottom of the cylinders. If you use a well designed rod, like a Callies Compstar or a K1, you should have very little material to remove.
