Dynamic Detonation and Cam Timing; VE gurus step inside
it can be argued that more exhaust duration is required because of the difference in efficiency between the intake and exhaust ports. But 8 degrees is a lot of compensation.
I'm not saying one way or the other is wrong but it should be open to debate for a street car. A shorter vs longer powerstroke has its advantages for specific applications.
For the the track I would actually go more to a 45 IVC and a 55 EVO. Try to cheat that power band up some. And center the overlap. 48 is getting kind of high if you do not intend to really rev it out. And would definitely need some compression.
Now for a street performance- not towing or hauling - truck, I would try to pull that EVO down to 40 and IVC down to 40 and zero overlap, which would be around 220/220-110 installed straight up. But it'll be done by 5500 in a 6.0.
What makes this hobby fun is the number of things you can do.
I would add 3.73s and a 3200-3600 stall from a reputable company, then have some fun with it and reassess your goals. Maybe throw some ebay headers on it if you want to be cheap. Should be in the 12s and you may decide that it is plenty fun just like that and don't need a cam at all...but if you want more, you will already have the proper supporting mods for it.
so here is where I'm at.
Just to reiterate, (I feel like some may have missed or disregarded my original posting) I've got a completely stock and heavy A4 2.73 geared 2002 z28 with a low mileage 2002 4.8 swapped in it with just blue springs, comp 212/218 115 lsa cam, and a good wide band street tune. It goes 14.3-14.4 @ 103-104 mph in 90°f+ 2000+da weather conditions with an appalling 2.35-2.40 60ft time. It doesn't spin at all and it only gets to shift once. It goes through the traps at just over 6k in second.
I was recently gifted an 01' LQ4 short block that needs new pistons. It will be going to the machine shop soon for an overbore and new cam bearings.
I was hoping to get the 6.0 short block fixed up with some budget pistons ( I'm leaning towards 6.7cc dish but that is still open for debate) and then swap the 706 heads and 212/218 115lsa cam from the 4.8 that I already have together in the car onto the 6.0, go and see what It runs and then go from there.
thoughts?
thoughts?
Others have suggested that I go dish to be safe for a daily driver but I really want to go flat tops and make what I have work for now if that is possible. Would a custom spec cam really be any better of a bandaid than the one I already have?
You are cooking dinner all over again without tasting it because you didn't like how it looks half way through.
I just want him to realize that jumping straight into swapping cams is not going to give him anywhere near as much gain as just finishing up what he started. If he is just looking for cheap fun, and has already said that his mid 14 sec ride "runs great for what it is", he will likely be very happy just installing the supporting mods he needs and not even touching the motor again. Just a cheap set of gears would be worth more in the 1/4 than any cam change would bring him, and also make the vehicle a ton more fun while putting around town. Add a stall and headers on top of that and he is likely good to go and will meet all his goals.
Once he launches a geared stalled auto with that small torquey cam and knocks out some easy 12s, I can pretty much promise he won't be happy with 14.4s anymore and may decide to keep his cam...or start thinking about some head work and the cams you suggested to really start having fun
. You are cooking dinner all over again without tasting it because you didn't like how it looks half way through.
I have owned a few of them and currently have two. My other one I've had since new and it is also an 02' z but it still has the original ls6# casting ls1 in it. It also has a 10" tci ssf 3500, custom built original to the car 4L60e built by Randy the trans man, 3.73's in the stock ten bolt with a girdle, and a few suspension bolt-ons though it still has stock torque arm and sway bars on it. The engine sports the usual fra, whisper lid, underdrive pulley, pacesetter 1-3/4 longtubes, custom 3in y-pipe w/cutout, and a Magna flow out the stock tailpipes. Internally It is cam and spring only as It also has a btr stage III RV cam with matching blue springs (218/224-113+3) and of course a really good wide band tune. With the idle up at 800 and the cutout closed the magnaflow hides the 46.5° of overlap at 0.006" very well.
I'm very happy with how this car runs but it's my baby so I just start it once a week and save it for the occasional drag strip blast and nice days or car shows. I'm fully aware of the benefits of changing rear end ratios, stall speeds and improving exhaust system efficiency. I learned a lot with that car.
This other car I have with the 4.8 however is a whole different story, it's more of an experiment with a placeholder engine that gets driven no matter what. I'm in this forum to learn more about engines, not chassis stuff.
I think at this this point in my life my idea of a nice daily would be a nearly bone stock looking and driving car with a little extra tq that anyone can drive (in case I get drunk haha) and that's what I'm wanting to achieve with this mild 6.0 and those god awful 2.73's I know the 4.8 would be an animal with a 4k stall and some 4.10's and so would the 6.0 but that's not what I'm trying to do with this car.
