LQ9/243 push rod length HELP
"Ideal" preload is within quite a wide range; .060" - .100" or so. It is not common for there to be so much variation between int & exh in a mostly stock motor that one length won't work on both.
Texa Speed sells push rods in .025" increments, no doubt others do as well. Find a length that puts both I & E in that range if possible, otherwise see if they'll sell half sets or at worst buy 2 sets.
One thing to verify is that the piston is at TDC on the firing stroke. Be careful using the timing chain for this, as when the dots line up #1 and #6 pistons are at the top but one is on the firing stroke and the other top of exhaust. Can't remember which was which with the timing chain (cam dot at top or bottom) for cylinder #1 so its best to rotate until you see the #1 intake close (use a pushrod to follow the motion making sure you keep some downward force on it to overcome the friction of the lifter tray that will likely keep the pushrod up) then bring piston #1 to the top. Then verify your measurements.
One recommendation, get larger OD pushrods like the 11/32" OD Mantons. You can also get them in separate lengths.
