243 vs 706 question
Old Jun 15, 2018 | 07:42 PM
Formula81's Avatar
Default 243 vs 706 question
I've read the article about the 706's being the best factory head for performance, ok, but my question is how much better do you think the 243's would be if you just milled them to get the same compression ratio as the 796's. Btw this is for a 5.3, I don't remember what motor they tested all these heads on. Thanks
Old Jun 15, 2018 | 08:20 PM
RB04Av's Avatar
The 706 isn't "the best factory head for performance"; it's the best on the 4.8 and 5.3, in unmodified condition. That's IT. They have smaller valves and otherwise less flow than any others.
243 is better generally. Has larger valves and better ports. They might be better on a 5.3 but only if it was set up for higher RPM use. Not in a truck w stock converter for example.
Old Jun 15, 2018 | 09:00 PM
Originally Posted by RB04Av
The 706 is the best on the 4.8 and 5.3, in unmodified condition. That's IT.
I think people forget that particular context. The 706 keeps the flow velocity up for those smaller engines, making good torque for them. The 706 would choke anything larger.
Old Jun 15, 2018 | 09:25 PM
Formula81's Avatar
Thanks for the responses guys, like I said it's going into a 5.3, with a small cam, but then if I were to get work done to the heads, which should I do it to?
Old Jun 15, 2018 | 09:34 PM
SLP IROC-Z's Avatar
243 milled
Old Jun 15, 2018 | 10:01 PM
I would go with some 706's as they are quite common, and do a bowl blend on them (that is where the majority of improvements of a port job are) and mill them to the desired compression. I think you will have surprising low end and throttle response!
wannafbody's Avatar
on that test, the 706 was only 2 hp better on a 5.3. That can be attributed to the compression increase.
Old Jun 15, 2018 | 10:23 PM
RB04Av's Avatar
^^^ This ^^^
Which means, cleaning up all the weird angles where the seat cutter got jammed into the casting, and the irregularity around the guide, and any particularly obnoxious casting flash anywhere. All without changing the basic shape of the port, and by removal of the least possible amount of metal.
Most of the rest of that stuff you hear about, above all "gasket matching", is just eye candy to dazzle those easily distracted by shiny things.
Old Jun 16, 2018 | 05:31 PM
Formula81's Avatar
^^^ This ^^^
Lol, I like shiny things,only kidding. I appreciate your answers, the reason I asked is because i have both sets of heads, but the 706's were on the motor when I bought it.
Old Jun 18, 2018 | 07:12 PM
cookseyb's Avatar
Send the 706's to Texas Speed and you will be amazed what they can do, 243's also then HANG ON!!
Old Jun 19, 2018 | 12:25 PM
Phil coppney's Avatar
You can also have 2.0 intake valves put in 706 heads.
Old Jun 19, 2018 | 01:02 PM
TSP's Stage 2.5 includes 2.02 intake valves. $950 plus springs on your head cores
Old Jun 19, 2018 | 08:48 PM
Formula81's Avatar
I know tsp does very good work, but this is,was, suppose to be a budget build, lol. I was basically wondering if I just had both heads milled, without having to change pushrods, and cleaned up and some kind of valve job, which would be better? I'm assuming they'd be pretty close yet.
Old Jun 19, 2018 | 08:53 PM
01CamaroSSTx's Avatar
What's your opinion on the 862's on say a 5.3 LS stroker 383?
Old Jun 19, 2018 | 10:35 PM
JoeNova's Avatar
Restricted User
Better than my opinion of a 5.3 stroker.
Old Jun 19, 2018 | 10:44 PM
wannafbody's Avatar
I'd suggest the extra port volume of the 243 casting on a stroker.
Old Jun 20, 2018 | 06:24 AM
I have a 4.8/5.3 over here with some 862s on it that I'm looking to do something with. I picked up some 243s from a member on here last year so I'm keeping my out for an LS2 block.
Old Jun 20, 2018 | 10:03 AM
cookseyb's Avatar
862's and 706's are like 243 and 799's same head just different casting process. I just got my 862's back from the machine shop with 2.00 intakes and 1.57 exhaust anxious top see how they perform..
