6.0L THIN head gaskets
Old Jul 6, 2004 | 06:46 PM
Ram Air Tony's Avatar
Default 6.0L THIN head gaskets
Is there a head gasket set that is thinner than stock to boost the CR a tad?? I know they exist for the LS1, but do they for the 6.0L ???
thanks in advance
RAT
Old Jul 6, 2004 | 07:00 PM
xp3nd4bl3's Avatar
Moderator
I put some custom gaskets on mine. Ordered them from cometic. I think they're .043" thick compressed.
Old Jul 6, 2004 | 08:32 PM
How much were they???
thanks
RAT
Old Jul 6, 2004 | 08:53 PM
xp3nd4bl3's Avatar
Moderator
I don't remember exactly. Pretty expensive, but they're awesome gaskets and I had the made custom bore size. I think I paid around $150?
Old Jul 6, 2004 | 09:08 PM
they got a website ??
THANKS
RAT
Old Jul 6, 2004 | 09:12 PM
www.cometic.com
duh
Old Jul 6, 2004 | 09:21 PM
1fstTA's Avatar
well Im having built right now a 423 iron 6.0 liter block and 6.0 liter heads and I bought the felpro 1041. gaskets they are 4.135 bore and .41 compressed. they better work on the 6.0 liter heads
Old Jul 6, 2004 | 10:06 PM
stock bored 6.0 liter is 4 inch bore, right?? does felpro make one that size in a thin version?
thanks
Old Jul 7, 2004 | 07:00 AM
texada's Avatar
what kind of compression will you have with this gasket? Are your heads milled?
Old Jul 8, 2004 | 03:03 AM
GTBMad's Avatar
Stay away from the Felpros 1041 they are rubbish blew 2 head gaskets just take a look at them and you can see they are not the real deal.
Using cometic now you can see the difference
Old Jul 8, 2004 | 09:58 AM
Taspeed's Avatar
you can use the late model z06 gaskets. they have a bore sufficient for a 4.030 bore, and I've checked em in at least 3 times at .043 crushed.
Old Jul 8, 2004 | 06:48 PM
so the LS6 gasket will suffice for the 6.0 liter bore of 101.6 mm even though the LS6 bore is 99mm??
if yes, then I guess the bore of the gasket isnt exact to the bore of the cylinder
thanks
RAT
Old Jul 9, 2004 | 10:44 AM
Taspeed's Avatar
yes they have been used and are sufficient for a 4.030 bore. Its close, but it works just fine with a FATTY shot of nitrous the bore size of the gasket is always a little bigger than the hole. How much depends on the gasket maker.
Old Jul 9, 2004 | 12:06 PM
BigTex's Avatar
How about a part number for those z06 gaskets?
Old Jul 9, 2004 | 05:20 PM
mbaskett's Avatar
actually, the ZO6 gaskets bore size is right around the 4" size, but I don't think they can accomodate a bore size above 4"... But I do use them on 3.905 bores all the time. They come out to be .047" crushed, although I've 'discussed/debated' this with Scoggin Dickey several times... the advertized crush is .065ish, but every time on the mic, they come out to .047 +-.001 Personally, I'll believe the measurments that I can actually see and check over advertised specs anyday....
The 6.0L gaskets are different than the ZO6 gaskets in that they have a larger bore, and these are the ones that can accomodate the 4.030 bore size, and probably even a 4.060 too. I haven't mic'ed a set of these crushed lately, but the last mic I did was on a set that had been preveiously crushed, and then removed from the motor, and my mic read in the .034ish range... although thats not the best/most accurate measurement method, so don't quote me on saying that's the final actual crush... I would assume it to be closer to the ZO6/LS6 gaskets thickness since they are the same design and each of the 3 layers is the same thickness and material type...
the GM part number for an idivudiual LS6 gaskets is 12573949 (they are identical/interchangeable from side to side)
The part number for a pair is 12498544
I have the pN for the 6.0 gaskets somewhere, just cant' find it at the moment...
Old Jul 9, 2004 | 10:55 PM
BigTex's Avatar
I know the 6L MLS gasket is a 4.040 diameter and can handle a 4.030 bore. From what everyone says, it is a .060 compressed gasket though.
Old Jul 11, 2004 | 01:13 AM
got the factory 6.0L gaskets, Matt and I and Chris are gonna put that beytoch together tomorrow and have it rollin in a week or so
stay tuned
RAT
