1998 trans am LS1 piston rods
The rod caps have a flat side and a radius on the other. According to the info i have found it says to install the rods with the flat side towards the front of the engine. When i went to the machine shop to pick up my engine block, one of the engine builders there that has many years of experience told me to install the rods with the flat side facing each other. So now i am not sure. Can someone help?
I believe this is to much gap for a daily driver. I am not supercharging or running nitrous. Im using Sealed Power Hyper flat top pistons H868CP +.025mm.
What do you guys recommend?
I am using an aftermarket manufactured aluminum intake from sharpcustomperformance.com with a 92mm throttle body and stock injectors. Do I need this fuel damper?
