Rocker Arm Clearance
Old Jun 24, 2018 | 08:18 PM
L33's Avatar
L33
Default Rocker Arm Clearance
Do I need to clearance my stock (trunion upgraded) rockers if I am running the large double valve springs?
Old Jun 24, 2018 | 10:50 PM
The outer spring should have same OD as a single spring as they fit the same pocket. So no, you should not have to clearance the rocker. Thousands of dual spring kits are in use with stock rockers.
Old Jun 25, 2018 | 08:04 AM
L33's Avatar
L33
okay, I just came across this while looking around LS1HowTo and i was wondering
Old Jun 25, 2018 | 10:12 AM
Are the springs you're using larger OD than stock?
Old Jun 25, 2018 | 10:33 AM
KCS's Avatar
KCS
Moderator
Most dual spring kits on the market are 1.3xx” diameter. The 1.43” diameter spring the picture said it was clearanced for will not usually fit a stock spring pocket.
Old Jun 25, 2018 | 10:37 AM
00pooterSS's Avatar
In the pic it says for a 1.43" spring, are you running a 1.43" spring???
