Crank but no start
Old Jun 30, 2018 | 08:53 PM
nathanl91's Avatar
Default Crank but no start
Hey guys,
new 5.3, fitech ultimate LS setup.
Heads, cam, flat tops, etc
motor cranks and blows fireballs out the exhaust, like it’s out of time..
we did swap valve covers, from driver to pass to put the fill cap on the easier to access side, are the coil pack setups specific to each side?
Tried a second crank sensor from another 5.3 no different... thinking maybe the chain is a tooth off?
Any other ideas?
Old Jul 1, 2018 | 01:54 PM
HappySalesman's Avatar
I'm assuming you've got some kind of PCV bypass (maybe an LS6 cover?) since the hoses on the valve covers are specific to each side...
Coil packs should be universal. You can always swap the coil packs to the other side to see if it makes a difference. Bracket just unbolts from the valve cover.
I'm assuming this is some kind of swap? ie, not a vette or fbody or truck?
Old Jul 1, 2018 | 02:50 PM
bandrew's Avatar
You need to swap coils/brackets back to original sides. The terminals in the main connectors for each bank are not pinned the same so your plugs arent firing at the correct time.
Old Jul 2, 2018 | 01:36 PM
nathanl91's Avatar
Swapped the coil racks back, Cranked 3-4 more times and Viola started right up.. FITECH said sometimes, it takes extended cranking for the ECU to get cam/Crank sensors to phase up Also.. Good info for anyone looking at their kits in the future.
Ive got a comp XR275HR in the Motor, And the idle sounds super smooth... Shouldn't i get some chop, Especially with Open headers right now..?
Yes its a swap, In our race jeep.
Old Jul 3, 2018 | 04:30 PM
00pooterSS's Avatar
The fire out the exhaust tells you it was firing out of time, not that you didn't hold the key down long enough. So swapping the coil packs was your fix.
