Piston ring ?
Old Jul 4, 2018 | 11:28 AM
Philhippy45's Avatar
Default Piston ring ?
I bought a tsp rotating assembly but it doesn't have instructions. The ? Is the 1st and second rings that have the chamfer on them has an n on them both I know it means napier but does that also indicate up or down or neither there is no dot and I don't want to guess which way the chamfer go. If anyone can tell me which way they install I'd appreciate it.
Old Jul 4, 2018 | 11:35 AM
Ls7colorado's Avatar
call tsp and ask them (tomorrow of course)
Old Jul 4, 2018 | 11:43 AM
I did yesterday and talked to two people and all they said was the shiny one goes on top and the dark one goes on the bottom.😵 I'm aware which goes were just don't know which direction lol.
Old Jul 4, 2018 | 12:45 PM
pantera_efi's Avatar
Default Piston Ring Installation
Hi Phil, the TOP ring has the inside bevel facing to the piston crown, to allow for gas pressure that pushes the ring to the cylinder wall.
The 2nd "N" ring has the outside notch facing to the piston skirt, to allow the oil to be scraped off the cylinder wall.
Lance
Old Jul 4, 2018 | 04:26 PM
Lance
But which goes up and down they both have n on them. So if the top one has the bevel going in which way is up? Same as bottom could some one give a good ish pic because i dont wanna mess this up. Lol
Old Jul 4, 2018 | 05:28 PM
slogo's Avatar
Im not trying to be rude, but it might be beneficial to you to get a how to assemble a LS1 book, lots of good info in those things
and they may point out somethings you are not aware you need to do.
Old Jul 4, 2018 | 05:31 PM
KCS's Avatar
KCS
Moderator
When the top ring has a bevel, it goes in facing up, or towards the piston crown as Lance said. The second ring is the opposite; the bevel faces down or towards the skirt.
Old Jul 4, 2018 | 07:29 PM
So here's the rings the top ring you can see how it sits in my hands and the edge rolls off a bit what i am getting at is either way I out the ring on itll be touching the piston but which way is up. Same for the bottom can some one take these pics and point out which is up lol.
Old Jul 4, 2018 | 09:38 PM
slogo's Avatar
Scroll down a little, good pictures. https://www.turnology.com/tech-stori...ng-technology/
So top ring pic, side that is touching your thumb goes to the top of the piston.
bottom ring pic. side that is touching your middle finger goes to the bottom of piston.
