Head Bolts
Old Jul 4, 2018 | 03:25 PM
SSNation's Avatar
Exclamation Head Bolts
If this is in the wrong section let me know and I will remove this.
I am putting 799 heads on my 98 Camaro and I went to torque the heads down all bolts went in perfectly fine but when I did the bolts "11 &12" in this picture the bolts snapped off inside the block. So my question is do I have to pull the heads off and somehow figure a way to pull these broken bolts off? I also did some research to see if its fine to run with broken head bolts but there is nothing online about these bolts.
Thank you in advance for the help!
Old Jul 4, 2018 | 04:21 PM
RB04Av's Avatar
Those are the smaller less important ones, not involved in the cylinder seal.
Just the same, they're probably important enough not to do without; if for no other reason than distortion of the castings.
Were these new bolts? I'm sure you're aware, stock (or stock replacement such as FelPro) can't be re-used.
Me, I'd pop em back off and get new and bolts (and gaskets if they had already been fully torqued other than this), and start over.
Old Jul 4, 2018 | 04:26 PM
SSNation's Avatar
Yes these are new bolts/gaskets
Old Jul 4, 2018 | 05:27 PM
HappySalesman's Avatar
Out of curiosity, what bolts were they? GM, Fel-Pro, etc
Old Jul 4, 2018 | 06:34 PM
truckdoug's Avatar
I have run without any of those bolts & I was rewarded with a nice oil mist underneath the intake under boost. Made great dust collection point!
You can weld those bolts out pretty easy on an aluminum block. Are they flush with the head or with the block?
Old Jul 4, 2018 | 08:34 PM
SSNation's Avatar
They are gm bolts
Old Jul 4, 2018 | 08:42 PM
11, 12, and 13 are deleted on the gen5 platforms, but I’d still want to see if I could get those out of there and put bolts in the holes.
Old Jul 4, 2018 | 09:43 PM
td1168's Avatar
You probably don’t need to pull the heads. I broke one off and spun it back up out with a drill and a 5/16” drill bit. I sharpened the bit to cut left handed and ran the drill in reverse. Spun the broke off bolt right up out.
Old Jul 4, 2018 | 10:53 PM
SSNation's Avatar
I tried everything and can not get the broken bolts out without taking the heads off (I dont even know if i can get the bolts out with the heads off) Do you guys think im fine just having 2 missing bolts, I got a small cam and ls6 intake
Old Jul 4, 2018 | 10:55 PM
kossuth's Avatar
I would try a left handed drill bit and see if I could back it out. Other than that I would be pulling the head. Did you chase the threads before assembly? Just wondering how you broke those bolts.
Old Jul 4, 2018 | 11:16 PM
SSNation's Avatar
Yes I did everything I was supposed to and when I went to torque them down they broke.. I don't understand how 2 broke and the other 3 were fine
Old Jul 5, 2018 | 08:38 AM
RB04Av's Avatar
Yeah that's weird, for sure. Especially 2 of em. They're 8mm bolts, and they get just a totally ordinary 8mm worth of torque; 22 ft-lbs or thereabouts. Same as any other 8mm bolt. No 8mm bolt should break with that little muscle on it.
Might want to use some other brand of bolts? FelPro for example. And follow their torque specs rather than the factory, since their metallurgy might be different and that's what TTY bolts are all about. (which the 8mm ones aren't... only the bigger ones)
Old Jul 5, 2018 | 01:10 PM
dawgs74's Avatar
I had #13 break on my 5.3.....and it was a mahle bolt....by then I was already done.....I said hell with it and sent it on it's way......haven't had any issues with it yet.....knock on wood........on my 370" they were engine pro bolts and I had no problems with any of them even the Lil head bolts had 10.9 on the head like the larger ones, the mahle ones didnt....not on the smaller head bolts for that matter........
Old Jul 5, 2018 | 01:19 PM
dawgs74's Avatar
Honestly I think you will be ok, just look out for the dust and oiling spot seeing how it's 2 bolts....luckily they are interior bolts and not perimeter. ..your not going boosted I hope....n/a You should be fine..good luck put up some pics if u got them...
Old Jul 5, 2018 | 01:22 PM
JoeNova's Avatar
Restricted User
Has happened to me a few times.
Spray some PB Blaster or Liquid Wrench or something down in there.
Take the top part of bolt that broke, drop it in the hole, and use an impact or bit driver and spin it slowly in reverse while pushing down very hard.
I do this to get broken head bolts out. So far has worked every time.
Old Jul 5, 2018 | 03:19 PM
00pooterSS's Avatar
If they aren't cross threaded they will come out really easy. Use a bolt head like Joe Nova said or my favorite thing is reverse drill bits. Grab a reverse drill bit like a 1/8" size and as soon as the bit grabs it'll unscrew the bolts.
You must have accidentally over torqued them, be really careful if you're using a click style torque wrench, it's really hard to feel the click at only 22 ft lbs. Slow and easy and feel very carefully for the click, or get a old school cheapy flex bar style torque wrench, they're only about $20.
As my body shop teacher always said "gently gently, not merrily merrily"
Old Jul 5, 2018 | 03:51 PM
RockinWs6's Avatar
Its possible there was something on the threads and that's why you broke them off. If that's the case and threads are a little jammed only thing gonna get them out is proper extraction. Personally I think I'd take a chance on it and run it like it is and I'm picky about what I let go.
Old Jul 5, 2018 | 08:08 PM
SSNation's Avatar
Thank you guys for the help! I am most likely just going to send it and check over it a lot at first!
