Roller lifter ID
Old Jul 11, 2018 | 09:43 PM
Rick5.3's Avatar
Default Roller lifter ID
Ok so i bought a lm7 from the junkyard a year ago. the lifters in it look diffrent than the ones i have seen. Is this a stock lifter that gm used or are they aftermarket? they have 5g1 stamped on them and the only ones i can find that look like that are from howard cams or comp.
Old Jul 11, 2018 | 10:01 PM
I’ve found conflicting info on this subject in the past, but from what I’ve gathered, GM started using the ls7 lifter in all its engines in 09? I think. The lm7 was out of production in 07’, so the lifters you have are probably the pre-ls7 unit?
Old Jul 11, 2018 | 10:12 PM
Rick5.3's Avatar
the motor was out of an avalanche and it was drive by cable. im not sure the year i may have an old bearing i can look at and see.
Old Jul 11, 2018 | 10:27 PM
Rick5.3's Avatar
main and rod bearings say 8-01 on them.
Old Jul 11, 2018 | 10:28 PM
Rick5.3's Avatar
is there any way to tell if the cam is aftermarket at home?
Old Jul 11, 2018 | 10:57 PM
Does it have a non-stock sounding idle?
Old Jul 11, 2018 | 11:20 PM
Rick5.3's Avatar
To be honest ive never heard it run. the block is at the machine shop getting cam bearings. the lifters have been sitting in a tuberware bowl full of atf for a year. i am rebuilding a lq4 for a 2500hd i just bought and just happened to.look at the lifters tonight.
Old Jul 11, 2018 | 11:24 PM
See if someone nearby has a CamDoctor. Or send the cam to someone who does. It will tell you everything about it.
Old Jul 11, 2018 | 11:39 PM
Rick5.3's Avatar
it cant be to special, im pretty sure it has the stock springs
Old Jul 12, 2018 | 12:00 AM
Not saying you're wrong, but single beehive springs are available in lifts up to .625. So....
Old Jul 12, 2018 | 12:22 AM
Rick5.3's Avatar
you know i think you might be right. these springs do look a little diffrent than the ones on my 317 heads
Old Jul 12, 2018 | 01:08 AM
Rick5.3's Avatar
ok so the springs out of the.5.3 are on the right. they have a yellow stripe, they are a little shorter. left are lq4, they have a green/blue stripe.
