LS2 cam gear trigger ?
You'd be better off leaving it unplugged than feeding the PCM a 4x signal when it's looking for a 1x
It may run, but run bad with the wrong signal. Same with it unplugged. If you're trying to get around putting a 1x gear on there or running a conversion box, you're not gonna
