Old Jul 28, 2018 | 07:25 PM
All Pontiac WS6's Avatar
Default 799
Hello All,
How much can you mill a set of 799 heads before you have to change push rod length?
Thanks, David
Old Jul 28, 2018 | 08:17 PM
Actually, you should check pushrod length any time milling is done. Even .01 (ten thousandths) is enough to need new pushrods, if the lifters are to do a proper job.
Old Jul 31, 2018 | 11:08 PM
poltergeist 02's Avatar
It really depends on what the current preload is and what lifter you are running.
Old Aug 2, 2018 | 02:13 AM
8.Lug's Avatar
With stock lifters you'd probably run your valves into the pistons before you ran out of preload.
Old Aug 4, 2018 | 08:56 AM
slogo's Avatar
I always enjoy learning new stuff, would you please explain this theory.
Old Aug 4, 2018 | 10:37 AM
Yes; this should be enlightening...
Old Aug 4, 2018 | 11:20 AM
Please do......
Old Aug 6, 2018 | 05:16 PM
00pooterSS's Avatar
It would be ideal to shorten the push rods by the amount that you shaved the heads. Picture the rocker arm on a stock deck head, now take .030 off the head, the rocker is now .030 closer to the lifter, so you just took .030 out of that distance.
However, lifters have a pre load range, and you can be in about a .100 range and be pre loaded just fine, so if you take the head .010 to .030 down or so, you should still be in that general range and be fine.
I was gonna google and try to find out what the factory pre load is and before I got to it I came across this article, this article is a good read for you guys interested in pre load etc.
I know the basics of pre load and that there's a range, range is different with different lifters, but I'm not sure what the factory pre load is, anyone know off the top of their head? Be good to have that info in here.
https://www.lsxmag.com/tech-stories/...oad-ls-engine/
Old Aug 6, 2018 | 09:49 PM
8.Lug's Avatar
From what I’ve read on here, the stock lifters have nearly 1/8” of travel. If your valves aren’t running into your pistons after shaving 1/8” off your head, that would be a damn miracle.
Old Aug 7, 2018 | 01:27 PM
MuhThugga's Avatar
You think someone is going to knock .125" off the deck?
Old Aug 7, 2018 | 01:37 PM
Consider the source....
Old Aug 8, 2018 | 06:59 AM
KCS's Avatar
KCS
Moderator
That’s BEFORE the lifters are preloaded .060”+. So you’re really only looking at about another .060” before bottoming out the lifter.
Old Aug 9, 2018 | 09:03 PM
Crysis's Avatar
So when is the ideal time to change push rod length after new cam???
Old Aug 10, 2018 | 06:49 AM
MuhThugga's Avatar
When your measurement concludes that your current set of pushrods won't work.
Old Aug 10, 2018 | 01:01 PM
00pooterSS's Avatar
During the cam swap
