6.0l Heads And Crank
Old Jul 7, 2004 | 04:16 PM
StrokerLS1's Avatar
Default 6.0l Heads And Crank
Just Wondering If A 6.0 Crank Would Work In A Ls1 Motor...im Sure It Will But Is It Worth It...i Have An Extra 6.0 And Was Going To Build A Stroker Ls1 Buy Putting The Crank In Also With The 6.0 Heads...by Putting The Heads In I Know It Will Lower The Compression Some But By Putting The Crank In Will It All Even Out I Guess You Could Say. But Will It Really Be Worth It Or Is It Better To Buy A Crank Already Set Up For A Stroker Just Trying To Keep Cost Down
