Water in oil after Spring change
Old Sep 6, 2018 | 07:56 AM
z28_YOU_HO's Avatar
Default Water in oil after Spring change
Just replaced valve springs in my LS1 and the damn air compressor i used to hold up the valves had water in it.
Went to check my oil after starting it and running it for 5 minutes and its all milky...Now ive had this happen to multiple 4 wheelers and typically ill just change the oil about 5 times and its good to go.
Is there a better option for this? What would you all suggest
Old Sep 6, 2018 | 08:32 AM
RockinWs6's Avatar
Change the oil and run it until its good and hot. Any moisture will burn off quickly.
Old Sep 6, 2018 | 10:52 AM
^^^^^^^This^^^^^^^^^^ If that's the only reason water got in, it WILL evaporate after some good hot running.
Old Sep 6, 2018 | 12:57 PM
z28_YOU_HO's Avatar
100% its because of the compressor...Going to change the oil after work, run it for 30 mins or so, then change oil and filter again.
Old Sep 6, 2018 | 03:36 PM
vettenuts's Avatar
I would also buy a water remover for the compressor if you do future motor work.
Old Sep 6, 2018 | 05:48 PM
z28_YOU_HO's Avatar
I’ll just buy a new one after this headache...Just flushed oil 3 times. Doesn’t look 100% but still going to send it!
I’ll probably change it again actually
