4.8 cam with lope help
Old Sep 10, 2018 | 01:02 AM
mercuno's Avatar
Default 4.8 cam with lope help
03 Tahoe, 4.8. getting long tubes now. Want to lope. Don't want a new converter but fine with getting new springs. Pretty simple I hope but need suggestions on the cam and a good tuner for all of this. TIA
Old Sep 10, 2018 | 05:39 AM
billymgb1000's Avatar
I used the GM hot cam came with the springs the specs are 219/228@50 .525/.525 lift 112 lsa, Awesome lope makes good power. Also mine is a 4.8 too. Forgot to mention that. good luck.
Old Sep 10, 2018 | 09:58 AM
^^^^^^^This^^^^^^^
Old Sep 13, 2018 | 10:27 PM
Bspeck82's Avatar
Maybe a comp cam thumpr cam?
Old Sep 14, 2018 | 02:15 PM
SRT8.Acelleration's Avatar
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:2,000-6,400
Intake Duration at 050 inch Lift:219
Exhaust Duration at 050 inch Lift:233
Duration at 050 inch Lift:219 int./233 exh.
Advertised Intake Duration:275
Advertised Exhaust Duration:295
Advertised Duration:275 int./295 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.553 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.536 in.
Valve Lift with Factory Rocker Arm Ratio:0.553 int./0.536 exh.
Lobe Separation (degrees):109
Camshaft Gear Attachment:3-bolt
Computer-Controlled Compatible:Yes
Grind Number:275THR9
Valve Springs Required:Yes
Quantity:Sold individually.
Notes:Cannot use stock springs. Stall converter 2000 and up is recommended. Custom computer tuning required.
Old Sep 23, 2018 | 11:45 AM
omc8's Avatar
If you like the hot cam ........take a look at the WS6 store version High Lift Hot Cam
Old Sep 23, 2018 | 03:32 PM
While this IS an excellent cam, I'm not sure a 4.8 needs all that lift (.600+/-) .525 (Hot Cam lift specs)is plenty for that size a motor.
