what is causing smoke on start ups?
The 2 piece seals can be a huge issue.
Thats why we only use the 1 piece stuff either for beehive or the tsp set for dual springs. never worry about seals again then.
If that doesnt fix it, then take the valve covers off and inspect the seals. Did you install the seals or were they installed by a shop? And HOW were they installed. If they were hammered on, it’s possible 1 or more may have been damaged.
The pcv baffles can get clogged so you can just soak them and clean them out.
Otherwise it requires more testing
Also idk why people keep using the melling high volume pumps but its very unnecessary and can be agitating your oil burning issue. high pressure only.
As as for the heavier oil, well thats a whole other story. I would be concerned leaving it in the engine long term. Sure it can be debated as to what’s best, but 20w50 sounds wrong. Bearing clearance will dictate what oil to use, so you’ll want to check this with your machinist too. Avoid any spirited driving before the oil is up to temp, or bettter yet just put the right stuff back in. Burning oil is better than burning bearings.
Ok interesting test with the oil weights. To me this seems to rule out PCV and valve seals as the issue.. Based on your findings, I would suspect blow by in your cylinder(s). You didn’t mention what weight oil you had in it before but it sounds like your rings are able to keep the heavier weight oil out of the combustion chambers. I would def talk with your machine shop on what they think.
