Rear engine cover?
Old Sep 24, 2018 | 02:45 PM
Jfwyatt1's Avatar
Default Rear engine cover?
If I pull the rear engine cover will I be able to see the rear cam surface to get the numbers off of it? I understand I will need to buy an cover alignment tool and new seals/gasket if I do this.
Old Sep 24, 2018 | 03:01 PM
Yes. The rear of the cam WILL be visible.
Old Sep 24, 2018 | 03:06 PM
8.Lug's Avatar
You won’t need an alignment tool, just use the oil pan.
Old Sep 24, 2018 | 03:21 PM
Jfwyatt1's Avatar
Ok thanks. Should I replace the barbell thing while I'm in there?
Old Sep 24, 2018 | 03:46 PM
Not a bad idea, IF you replace it with Sac City Corvette's Billet Barbell, a precision-machined replacement that seals better and potentially increases oil pressure.
