How to decide what cam to use?
Old Oct 2, 2018 | 01:12 PM
Summitracing's Avatar
LS1Tech Sponsor
How do you want to use the car? Daily driver? Weekend warrior, roll racing, autocross, road racing, street/strip, mostly strip, all out drag strip? Dyno-Queen max peak numbers?
Desired use is a factor in cam selection.
This! Deciding on the best cam for you is 1/2 interview and 1/2 what it takes to go down track the quickest. If you want to take a look at some of the methodology behind the Summit Pro LS cams, here's a link to an article we did on the subject. We will have another announcement later this week on the subject.
__________________
800-230-3030
www.SummitRacing.com
Old Oct 2, 2018 | 07:22 PM
99 Black Bird T/A's Avatar
Originally Posted by Sksimmortal
Well it's going to be mainly street strip but not a daily. If I want to drive it I'll take it out and I'd rather something a little more wild. The bottom end is going fully forged and I'm pretty sure I'm going with the 383 stroker setup. I'm trying to stay n/a with it but if I dont get the desired feel from it then it's going to be turned toward boost. I've been looking into the voodoo cams but I dont know anyone that has any and everyone I've talked to personally about the cam says its a really big cam. I've never had to decide on a cam before so I dont know what to look for in deciding. Ive installed them so that's no big deal work wise just havent been able to figure out how to decide on a cam yet. Ive done numerous searches for a good set up with 243 heads but the amount of different cams running with the heads I cant figure out what would be suitable for me. I tend to do alot of roll racing so my rpms are always higher than 3k and I'm debating on making the limiter changed to around 7k like the ls2 gto but even with all of that the last deciding factor is the cam. Once I figure the cam out I'll be able to determine the springs and everything else for it. If you need more info on the car or w.e just ask because I don't know what all factors change for a cam.
I would definitely decide now if I wanted a boosted set up. Building the best NA set up means 11.3 to 12 to 1 compression for 93 octane pump gas and will be getting into too much compression boosted unless you want to go E85 or change to lower compression cylinder heads. Also build a good NA 383 LS1 stroker means 4 inch crank and the piston will have to be selected accordingly. That type of piston isn't as well suited to boosted applications because the area for the tingling tends to be more compact. I have a 383 LS1 stroker I'm speaking from experience on how we built it.
I've never done a turbo or supercharger set up so I don't know exactly the cost or what's involved. Junk yard 5.3 with turbo sounds like the hot set up these days. I'm a daily driver type and road trip my stuff 1300+ miles so I've stayed NA with all of my builds and cars.
FWIW - a 4 th Gen M6 with good heads and cam LS1 with 4.10 gears is alloy of fun with out being a budget buster. Making ~430 to 450 is pretty budget friendly if the motor is in good shape. I know three people plus my self that have LS engines with 250,000 to 300,000 miles on them that are running great. Another torn down a 297,000 mile 4.8 for a turbo build that still had factory cross hatchin in the bore. He said he'd have just ran it if he'd have know that
Spray can add a lot of power for the price. I've not used it but had my 383 LS1 built to take a 200 shot in case I want to one day.
Honestly, deciding on a budget of how much money you are willing to spend. Doing a 383 LS1 stroker short block from say will cost ~$3900. With your goals in mind the Scoggin Dickey Performance Center 427 LS short block with 24x crank for ~$5,200 are good affordable starting points.
SDPC LS. 383 Aluminum block
Scoggin Dickey 427 LS
A quality top end package heads , cam intake can easily hit $4,500
​​​​​​So for that 383 LS stroker I would be planning $9,000+ for the 427 say $10,000 +
Fuel system - will need upgrade $300 to $700
Transmission - probably need at least a new clutch set up $800 to $1500 easily
rear end - at least a Hawk's 8.8 or MWC 9 inch, plan $3200 to $5000
headers, y pipe or x pipe dual - plan on $1000 to $3000 depending on what you want
Other suspension stuff torque arm, rlca, panahard etc $800 to $1000
Don't forget tires & Rims $500 to $5000+ depends on what you want
Install & tune
FWIW - in my ~3200 pound RS Camaro when 465 whp 442 wtq 383 LS1 is fun to drive, has good street manners. The TA with 517 whp & 471 wtq (way more low end torque ) is fun too but it's much harder to hook up the power on the street. From a hard roll both are fun but the RS my choice because it hooks better. With a few tweaks that compromise drive ability either car could gain another 25 whp to 50whp.
You might want more than that...a lot of folks do.
Old Oct 3, 2018 | 06:41 PM
wannafbody's Avatar
For a M6 street car, you can't go wrong with a BTR stage 2 or a Cam Motion Titan 4.
