6.0L weird oil pressure problem
2005 chevy blue bird bus (Short Bus) using for a tow rig. 6.0L 4l80e 2wd 227k bought it from a school in southern mn at auction maintenance is unknown ...
When i received the bus i noticed it was at 15lbs oil pressure during the summer and around 30 causing down the highway so i overfilled it by about a quart and noticed oil pressure increased as i added more oil .... now the hot idle is at 25lbs and 40 causing down the highway which from what i read is low but is acceptable.... lately the weather has been getting down into the 40s and 30s here and on cold starts i get like 15 psi and eventually and now 35lbs crusing down the highway. i also heard a lifter ticking for a brief 30 seconds or so then went away. I've changed the oil and used stock 5w30 mobile 1 SYN and a Wix filter. My question is.... does this sound like a dying o ring at the pickup tube or the oil pump going out ? getting somewhat nervous over here...
idle speed is 600rpm and 2300 at 65mph
If you do decide to tear into it for the O ring, I would also be prepared to swap the oil pump out (as mentioned). However I think I would opt for the Melling 10295 high pressure pump in this case. If you go through all that trouble and replace the oil pump with an oem replacement, if it turns out the old pump was fine you would end up with the exact same performances you have now.
cam thruster plate on front
oil pickup tube
mellings oil pump (HIGH PRESSURE)
O-ring supplied with kit
all gaskets etc
hoping to get another 50k out of this thing at least .... even with blackish trans fluid : )
And change the tranny fluid if it's black...
put a new oil pump in from millings the high press and high volume. turns out that little red o-ring was cracked and has a small chunk missing allowing air to be pulled by. while i was in there put in a custom grind cam from comp and a cam retainer plate etc. i have rock solid oil pressure at 55psi at idle with a hard rev it pegs the gauge at 80. Thanks to everyone whom pointed me in the right direction hopefully this thread will help the next person in line !
By the way for those looking for answers, the lower oil pressure when cold was kinda the giveaway for the o ring, pressures are always higher when cold since the oil is thicker when cold. Being cold it was harder for the pump to suck up the thicker oil and things contract when cold. The O ring swelled a little in higher temps and helped the pressure.
O rings do go bad over time, they harden and lose their seal, and as you already know, they sometimes crack too. Rubber ages out, pick up an old rubber band and pull on it, same thing happens to rubber in tires gaskets etc.
