H/C car idle problems
BTW, the only LS engines that need a high volume pump are those with DOD or VVT, or both.
With that said, is there a lot of carbon build up in the throttle body? Sometimes a good decarbon treatment and cleaning the TB can help. If the IAC passages in the TB are full of gunk they may need to be cleaned too. When my TA had a bad valve seal oil would get tossed back into the intake and end up in the TB. I would pull the TB and check it for build up and dirt if that's not already been done.
If the TB is really dirty the vehicle may still idle poorly until the PCM gets an idle relearn.
My 250,000 mile 02 Z28 would take issue with being called an a "notorious oil burner". Burned 1/2 a quart over the last 4,000 miles, less than my Tundra burns
My TA and RS both stroker LS engines burn even less than oil than the Z28.
Often when an LS burns a lot of oil a valve seal is bad. Getting that fixed isn't a big deal.
BTW - I would add an LSA or LS9 block with oil squirters for the pistons to the list of applications where a high volume oil pump is needed.
How does the car react in stop and go driving? Cold Vs hot idle?
If it was fine for 2 months it makes me think its not tune related.
