Carbed LS build idea
Old Dec 17, 2018 | 02:38 PM
84Mercedesguy's Avatar
Default Carbed LS build idea
Msd 6014 ignition box
Holley sniper intake
Btr stage 3 truck cam
850cfm ****** alcohol carb
150 shot
6.0 LQ4
fbody pan
3000 stall
th400 from a 76 454 C10 stock valve body
Ford 8.8 with 4.56 gears and C Clip eliminators and full spool
The car is a 1986 mustang notch
Old Dec 17, 2018 | 02:48 PM
Ls7colorado's Avatar
more compression?
and why not go with a custom cam more for a carb setup?
Old Dec 17, 2018 | 05:16 PM
00pooterSS's Avatar
150 shot
6.0 LQ4
fbody pan
3000 stall
Cool cool
Old Dec 17, 2018 | 05:46 PM
more compression?
Might put LS9 Gaskits on there to bump up compression a lil bit
and custom cams are a lil pricey from what ive seen
Old Dec 17, 2018 | 06:25 PM
there not much more, or just get a off the shelf carb cam but the btr stage 3 will work fine anyways.
ls9 gaskets are the same thickness I believe
ws6 store has .45 gaskets witch will help a very small amount witch is what I’m going to be running with 243 heads witch will bump compression a little over 10.5:1
