Help with Cam Shaft Info??????
Old Dec 19, 2018 | 07:21 PM
CB99SS's Avatar
Default Help with Cam Shaft Info??????
I'm trying to figure out what brand cam and details of it that is currently installed in my 99 camaro. On the end it has the following.
RRS1-231-231 UA7D 112
241820 (Is engraved in it) The 0 may actually be an 8 or 9.
Thanks for the help.
Old Dec 19, 2018 | 08:00 PM
If it's 231/231 with a 112LSA (jus' guessin'!), I bet it lopes a bit. Does it?
Old Dec 19, 2018 | 08:06 PM
wannafbody's Avatar
I'm guessing a Comp Cam
Old Dec 19, 2018 | 09:15 PM
CB99SS's Avatar
Yes it lopes. But I got shafted because the motor is suppose to be for twin turbos.
Old Dec 19, 2018 | 10:09 PM
If the numbers I quoted above ARE the actual specs, then NO, that is not a turbo cam. Who sold it to you?
Old Dec 20, 2018 | 05:29 AM
CB99SS's Avatar
Someone I thought was a friend.
Old Dec 21, 2018 | 11:48 AM
Broken944's Avatar
What would make that not a turbo cam? I don't know if just the duration and LSA is enough to determine something like that.
Edit: with a little googling, the 'RRS1-231-231' looks to be in the same format as Lunati grind numbers found on Summit. I cant find that specific grind number anywhere. Custom grind maybe?
Old Dec 22, 2018 | 08:45 PM
A turbo cam would have a wider LSA, like at 115 degrees. Too narrow an LSA keeps boost down by letting intake compression blow right out the exhaust with excess overlap.
Old Dec 23, 2018 | 11:37 AM
Darth_V8r's Avatar
Moderator
You typically see longer exhaust durations vs intake on turbo also because you get all those spent fumes out
Old Dec 23, 2018 | 11:43 AM
Also true for PD blower cams, right? Same reason?
Old Dec 23, 2018 | 01:43 PM
Broken944's Avatar
Typically maybe, but I've seen plenty of turbo cams on 112s and with lower exhaust durations. It dependson what the motor needs. The LSA is just a number that comes from the valve events. With the info given we don't know the valve events. Just duration and LSA doesn't say enough in my opinion too say it's not a turbo cam. It might not be, but also it very well could be depending on the actual valve events.
Also, I'll throw it out there that longer exhaust durations might hurt spool times on a turbo. Hold that valve open to long and the exhaust gas velocity drops. I'd think you want to keep that exhaust gas hitting the turbo moving as fast as possible.
