Compression test results Should I be worried
if there is a special ratio on the LS I’m sure someone will correct me. But those numbers look perfectly fine as a general standard.
Consistsncy between all the cylinders is the most important. As long as it’s not SUPER low.
it will also vary depending on your compression ratio/heads.
I'd consider 150 psi to be the lower limit of a good running engine, but "good" just the same, depending on the other variables.
You said that the pressure was even across all eight cylinders, so that is a really good sign.
The only thing that would make me curious is that you said there was fresh oil on the plugs.
How many miles do you have on this shortblock?
However, it is more than likely that the valve events are "bleeding off" the dynamic compression ratio.
Thus giving you the 150.00 PSI found.
As states by ck 32... good news is that all cylinders show aprox. equal pressure.
More than likely everything is fine.
Was the test done wet or dry?
FWIW when I'm trackside I don't even have a compression tester in my toolbox I have a leak down tester..
Some cars get a leak down between sessions.. It will catch valves letting go before its a bad thing..
