Timing chain damper
i am building a 2005 lq4 and wanna install a chain damper. I only have one hole drilled and tapped on my block is it better to tap 2nd hole or just run the bracket. Also what chain setup will be best a single or double. Going to go with flat tops ls3 tip end and cam NA buildni. A 99 Tahoe 2dr
