.600 Max lift
Look at this chart here: https://www.racingsprings.com/index....s-springs.html
a .600 spring has an installed height of 1.800". A .650 spring has an installed height of 1.900".
All commonly used cylinder heads are sand cast. You can get billet, but they're pretty expensive. "As Cast" means the ports and chambers are exactly how they came out of the sand cast. No porting, polishing, or smoothing. As you would expect, there are some very small variances in the surfaces that have not been machined. You can hand port and polish them, if you know what you're doing. Or you can have them CNC machined. It's a significant price increase, but not a significant power increase. If you're racing and need every last hp, then it's worth it. If you're building a fun street car, probably not.
The as cast heads are pretty much self explanatory, the ports and chambers are as cast with little to no porting done, however, they are based on a ported head so the ports are a lot better than a stock head. You can port them further as there is still plenty of meat left in them to go bigger.
