Help with first ls1 build
Old Mar 30, 2019 | 06:29 PM
Brootaljoe's Avatar
Default Help with first ls1 build
I have a 2001 Z28 with ls1 5.7l with 241 heads 118k miles cylinder 7 has lost of compression its 50-70psi. There's oil getting in the cylinder but I have no oil bypass from my crank case like I have no pressure even I take the oil cap off. I checked cam vavles arm to be moving fine can barely tell the miss in cylinder 7. but I have air bubbles in my rad when I rev it. I was going to tear the motor down and replace all my pistons and rings. But I don't know what I should replace them with I was just going to stick with stock or go with foraged pistons stock size if I can. But I'm lost on finding what I need. Any help would be appreciated
Old Mar 30, 2019 | 10:29 PM
bammax's Avatar
Sounds like a blown head gasket. Pull that head and see what's going on before buying parts. Definitely don't keep running it until it's fixed.
Old Mar 31, 2019 | 06:38 AM
Brootaljoe's Avatar
Default Headgasket
It's sitting in my driving it I thought it could be va head gasket too but I read on here about how cylinder 7 has problems and how the aluminum heads warp so I thought about just tearing it down and doing a complete rebuild. I just don't know what steps I got to take.
Old Mar 31, 2019 | 06:47 AM
01CamaroSSTx's Avatar
There are some pistons out there you can use with your stock connecting rods but if it where me I'd be looking for a decent set of forged rods and pistons. You can reuse the crankshaft but you will need to send in the new rods, pistons and crank to a engine machine shop be balanced before assembly. Depending on what you plan to do with the engine will dictate what direction to go with your piston selection.
Old Apr 5, 2019 | 04:29 PM
transamcustomz's Avatar
Veteran: Army
get a junkyard 6.0 L. youll rebuild that LS1 and want more power, then throw 2-5K (modest estimate) at it and could have had said power from said junkyard 6L for probably less $
