862 vs 806 stock heads
Physically they will bolt up and mechanically they will work, but You will Lose power.
The combustion chamber is larger and will lower compression ratio. You will likely lose a little port velocity on that smaller bore application.
http://www.superchevy.com/how-to/eng...der-head-test/
