NSR Cam Question
Old Apr 16, 2019 | 10:22 AM
Carp's Avatar
Default NSR Cam Question
I’m gonna help a buddy this weekend install a summit 209/217 .500 lift NSR cam on a 2004 5.3. Not pulling the heads so my question is are the pushrods still required to be removed or can you rotate the cam enough to get the two wooden dowels in to keep the lifters from falling in or will the pushrods not have enough room with the rockers still bolted down? First cam swap without changing springs so I’ve never had to worry with this question before.
Old Apr 16, 2019 | 11:09 AM
panda240ss's Avatar
you can do the dowel trick i did it, i went to home depot and picked up a long *** dowel and just kept rotating until the dowel was at the end and swapped cams. just make sure u dont break the dowel
Old Apr 16, 2019 | 12:04 PM
Carp's Avatar
But do I have to pull the valve covers and remove the pushrods?
Old Apr 16, 2019 | 12:09 PM
panda240ss's Avatar
yeah you do because if im correct to put tension on the lifters which is was you want to lift up.
Old Apr 16, 2019 | 12:35 PM
Darth_V8r's Avatar
Moderator
Pull the rockers. Spin the cam. Insert the dowels. It will require some force
Old Apr 16, 2019 | 01:47 PM
panda240ss's Avatar
Its simple as i said just make sure not to break the dowels! if not your gonna have a baddd time!!!
its a nice cam i had the BTR one before i got my SS2 Cam
